Snara.21
Senior
Jul 27, 2021 2:35 PM UTC
I want to create a project with BLE read and send the sensor data. Is there is any step by step guide to work on this
Jul 27, 2021 3:26 PM UTC
Hello @Snara.2​
Please have a look at the AN5289 Application note Building wireless applications with STM32WB Series microcontrollers.
You can also refer to the attached presentation, demonstrating how to use our STM32CubeMX for starting your BLE application project for the STM32WB module discovery kit.
Hope this helps you!
Please select my answer as Best if it fully answered your question, so that this thread will marked as solved.
Imen
Snara.21
Snara.21Author
Senior
Jul 31, 2021 2:05 PM UTC
@Imen DAHMEN​ . I have gone thro the presentation. The steps we see in the presentation is not seen, If I select the STELVAL_MKSBOXV1
The step by step procedure shows as follows but not seen in the Cube MX
Javier1
Principal
Depends of the sensor, if its one of those dammed HeartMonitors or temperature sensors youre in luck because there is plenty of working examples already.
hit me up in https://www.linkedin.com/in/javiermuñoz/
