Meng
Sep 25, 2019 7:56 AM UTC
I dont get the i-cube_lrwan V1.2.2 endpoint working for B-L072Z-LRWAN1
Everything seems to work fine in putty except the join, but the signal is not received by TTN, while it is received when i use v1.1.2 (https://github.com/drakkar-lig/st-lrwan). I changed the devEUI, appEUI and appKey.
kris10.5675552917061943E12
Sep 25, 2019 10:55 PM UTC
Did you make sure you are using the right frequency?
