Marcuka
Feb 14, 2022 9:24 AM UTC
I-CUBE-LRWAN flash optimization
I need more 4kB of flash memory. Can I achieve this easily and safely by removing some not used functionality in the I-CUBE-LRWAN project?
I suppose Lorawan Class B and C featues will not be needed. Can I just exclude this files from the project and remove the corresponding function calls?
Thank in advance,
Martin.
