ELecl
Feb 5, 2019 12:50 PM UTC
I CUBE LRWAN
I trying to use an STM21L073 Nucleo-64 with my custom board LoRa (SX1261). I use your code I CUBE LRWAN version 1.2.1.
At this time I can see JOIN procedure start. The node send a request JOIN to our GW and GW send a Accept JOIN. But in Tera Term Terminal each time node send a JOIN request, I have this message "PHY txTimeOut".
The node never send a message to accept JOIN from GW. (GW work with a different node).
Do you have some advice ?
Edouard
