How to use "provisioning" and "proxy" services to control the BLE mesh? Are there have guidelines about these data formats?
I'm a novice in STM32WB and BLE mesh. I have started using the "BLE_MeshLightingPRFNode" example test with the "ST BLE MESH" APP. I want to use the "vendor model" to transfer the segmented and unsegmented packets in BLE mesh network by a host node that can be a proxy node or gateway node.
Although I successfully used the "ST BLE MESH" APP to communicate with the node(STM32WB5MM-DK) running "BLE_MeshLightingPRFNode" by the "vendor model". But I need to know how to use the provisioning & proxy service to communicate with mesh and its interaction.
There are the questions below.
- In GATT "provisioning" & "proxy" services have "data in" & "data out" characteristics. I want to transmit the different data to test, trace, and check the interaction in the code. Are there guidelines about data packet format for these services and characteristics?
- How to transmit/receive the segmented and unsegmented data? Does BLE stack handle it? And we only need to decide the data length want to send?
