LR.2
Jan 10, 2023 4:37 AM UTC
How to transmit 16-Bit audio via BLE. - STM32WB5MM-DK
I'm working on transmitting audio over BLE. I have successfully connected SPH0645 mic using I2S and also I have connected speakers for the output. The thing is I don't know how to transmit audio over BLE. I tried creating custom template to notify the audio value buffer. Can anyone help me with this. Thanks in advance.
Javier1
Principal
Jan 10, 2023 8:40 AM UTC
transmit audio over BLE to where? android/windows/....
Does your receiver side have (hardware)BLE5.0 at least?
Here you have the theory, you broadcast the audio stream.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjok86dzbz8AhXATqQEHRRRCxgQwqsBegQIEBAE&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DVqwBJlFqh0U&usg=AOvVaw0vuBgxXf--OTPGW6knITEI
hit me up in https://www.linkedin.com/in/javiermuñoz/
LR.2
LR.2Author
Jan 10, 2023 9:07 AM UTC
Hi Javier,
I'm transmitting to my laptop. Using python I receive packets in a bytearray. Then I convert those to audio file (.wav).
I managed to notify the data but the data what I'm getting is not the data what I'm sending.
Javier1
Principal
Jan 18, 2023 9:01 AM UTC
Are you sure this is fast enough?
Remy ISSALYS
Jan 18, 2023 8:27 AM UTC
You can look FP-AUD-BVLINKWB1 function pack which allows to perform full-duplex voice streaming or stereo music streaming over BLE using the advanced Opus compression algorithm.
Best Regards
Javier1
Principal
Jan 18, 2023 9:02 AM UTC
