Sep 24, 2024 1:16 AM UTC
How to terminate unused RF pins
If I have a design where I am not using the RF pins, is there a recommended way to terminate them? Can you just ground them all?
STTwo-32
STTwo-32Best answer
Oct 4, 2024 9:09 AM UTC
Hello @AJ_1
For the RF pins that are not used, there is no recommendation on how to connect them. You can even leave them floating. Ther is no degradations that have been observed for this configuration.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @AJ_1
Best Regards.
STTwo-32
