SSaya.1
Aug 9, 2021 7:20 AM UTC
How to stop the example program getting recovered ?
when the example file is modified but the original program gets recovered when the Device Configuration Tool Code Generation is hit after some changes in ioc file.
#stm32wl55jc
Its hard to start from the scratch in LoRa subghz, Do anyone have some methods?
Thank you
Paul1
Paul1Best answer
Senior III
Aug 9, 2021 3:46 PM UTC
If you modify any generated files:
  • Put code only between the comments that say "user code here", and click the checkbox for retain user code: MX > Project Manager > Code Generator > +"Keep User Code When Regenerating"
  • Keep your code in a version control system, or at least zip projects and put on a backup device.
  • Don't put your code in main.c, Put your code in main2.c (or main2.cpp), and put a call to main2() in main(). When regenerate ensure the init code in main2() is updated to match main(). Few extra steps needed for change to support cpp files.
  • Better yet put all your own code in a separate folder (ProjectCode or MyCode, next to Core)
  • Create a document to log **all the changes** you do to generated files, so down the road you or others will know how to create similar projects, or recreate this project if it gets corrupted, or a major STM32Cube change occurs and auto update doesn't work.
Paul
Paul1
Paul1Best answer
Senior III
Paul
Aug 9, 2021 5:48 PM UTC
Develop and modify code in a sandbox, not in a directory/tree that automated tools are likely to overwrite, modify or delete.
Move your code into a sandbox, and use source code management tools to archive/save it
