KKIM.6
Senior
Feb 13, 2023 3:01 PM UTC
How to send multi packet and is there any example?
I want to send 2 kbyte data using BLE in WB55.
Becasue the packet size is limited to 245 byte (it may be 509 byte if change ATT-MTU to 512 but still I couldn't make it.)
So, I wonder whether there is good example for this.
Could you suggest anything?
Javier1
Principal
Feb 13, 2023 4:38 PM UTC
You just chunk it down to 245 byte packets.
Im not sure im understanding your issue.
hit me up in https://www.linkedin.com/in/javiermuñoz/
KKIM.6
KKIM.6Author
Senior
Feb 13, 2023 4:42 PM UTC
If I divide data into 10 set, there maybe missing data during transfer. Then how can I solve it?
Javier1
Principal
Feb 13, 2023 5:07 PM UTC
You could ping pong the same data and check if it matches, maybe some CRC, or your own custom header wrapping your payload.
