How to save the OTAA join parameters in the memory permanently?
Hi everyone
I have been working with the BL072Z-LRWAN using the AT Slave software provided by stm.
In our custom devices , we are using the same module and to save power we have a relay to turn on and off the module , as and when required.
But the problem is that whenever i switch off the module , the key and OTAA join parameters are lost , and to send data over LoRa , we have to initiate Join Command again , which is not a good way to go.
Can you please guide me on how can i save the join parameters in the memory so that i don't have to do it again?
Is there any AT command to save the information?
Thanks and Regards
Rajat Kalyan
