NMeno
Aug 10, 2023 9:10 PM UTC
How to reboot a STM32WL from code?
Hi, I'm using a STM32WLE5CCU micro with FW_WL V1.3.0 library. I want to implement a feature that receives a downlink command from the Network Server and reboot the entire system like pushing a reset button will do.
Once the command is received, is there any local function I can use for this purpose?
Any example of implementation?
Thank you!
TDKBest answer
Aug 10, 2023 11:53 PM UTC
Calling HAL_NVIC_SystemReset() will reset the system.
TDKBest answer
NMeno
NMenoAuthor
Aug 14, 2023 3:38 PM UTC
Hi TDK, thanks for your reply, it worked like a charm!
