Huzaifah Limbada
How to port I Cube LRWAN Nucleo code on Discovery boards?
Hi, I'm using the OTAA sx1276mb1mas of End_Node code of I Cube LRWAN V 1.2.0(Downloaded from STM).
I want to use that code on STM32L152 discovery board, for that i'm converting with understandable changes and generate it from CubeMX.
Now by disabling Low power mode(For debugging) i'm trying to send the data randomly, but after initialization and performing all the init procedure it won't display anything like Txtimeout or TxDone.
Now i'm completely tiered from this because i'm not getting where it has been stuck or where is the problem.
Can anyone help me for this?
Small help can create an big impact for me.
Thank you!
