How to make reporting configuration persistent
I am working on a Zigbee application using an STM32WBA65.
I am trying to make the attribute reporting configuration persistent.
Persistence works correctly: when the device reconnects to the network, the values of attributes marked as persistent are successfully restored; however, this is not the case for the reporting configuration, which reverts to default values.
I have not found an API that allows for the detection of changes to the reporting configuration.
BR
Anthony S.
