JayRullia
Aug 3, 2023 8:49 AM UTC
How to make larger STM32WB55 ZigBee Neighbours Table size
Hi.
I am working on a ZigBee project for the STM32WB55.
I use Zigbee wireless binary of STM32Cube_FW_WB_V1.16.0 as below.
stm32wb5x_Mac_802_15_4_fw.bin, stm32wb5x_Phy_802_15_4_fw.bin, stm32wb5x_Zigbee_FFD_fw.bin.
It works well for now with using
zigbee_app_info.zb = ZbInit(0U, NULL, NULL);
Now I need larger nwkNeighborTblSz  to have more nodes, I tried following code.
static void APP_ZIGBEE_StackLayersInit(void)
struct ZbInitTblSizesT tblSizes;
tblSizes.nwkNeighborTblSz = 64;
tblSizes.nwkRouteTblSz = 32;
tblSizes.nwkAddrMapTblSz = 32;
tblSizes.nwkBttSz = 32;
tblSizes.nwkRReqSz = 16;
tblSizes.apsPeerLinkKeyTblSz = 32;
tblSizes.heapSz = 32*1024;
tblSizes.heapPtr = malloc(tblSizes.heapSz);
zigbee_app_info.zb = ZbInit(0U, &tblSizes, NULL);
My board does not come alive..
So I tried below codes but the board does not come alive..
tblSizes.heapSz = 0;
tblSizes.heapPtr = NULL;
1. Anyone can tell me what is wrong in the codes?
2. They say the default value of nwkNeighborTblSz is 64 but I see only 16.
I use  FFD (stm32wb5x_Zigbee_FFD_fw.bin) as wireless binary and use
And the default value of apsPeerLinkKeyTblSz is said as 32 but I see also only 16.
Anybody can help me by anwer the upper questions?
Thanks in advance.
JayRullia
JayRulliaAuthor
Aug 7, 2023 3:03 AM UTC
Hi. everyone..
Actually I got an answer why the following code does not work..
I chaged tblSizes as global variable and the machine begin to work as I expected..
I guess
ZbInit(0U, &tblSizes, NULL) keeps using tblSizes variable after returning non-null zigbee stack pointer.
Here I write the answer to my question because I want other guys to see it avoiding same mistake.
Good luck.
