KKIM.6
Senior
Feb 13, 2023 3:29 AM UTC
How to do factory reset for stm32wb55VG6TY microcontroller?
During several trial to use ACI_GATT_Write_Long_Char_Value,
I found that the microcontroller dosen't start its BLE advertisement anymore.
It only can indicate wireless firmware version.
I think that some transmission cause an error.
So, I tried to rewrite FUS and Wireless Stack firmware but it couldn't solve the problem.
So, I wonder that there is any way to reset microcontroller completely.
Javier1
Javier1Best answer
Principal
Feb 13, 2023 8:39 AM UTC
There is a lot of peple having issues with the FUS wireless stack (me included)
Are you 100% sure youre using the correct version and youre programming it in the correct flash memory address? they do change.
Also using an outdated cubeProgrammer doesnt help either.
hit me up in https://www.linkedin.com/in/javiermuñoz/
Javier1
Javier1Best answer
Principal
KKIM.6
KKIM.6Author
Senior
Feb 13, 2023 2:47 PM UTC
There was wrong code. So, this problem solved by changing code.
Thanks for responding.
