ngodoanvan
Jun 12, 2022 8:16 AM UTC
How to configure the stop mode in LoRa application correctly?
I tried to generate a new project follow SubGHZ_Phy_PingPong example project which does nothing, to test the stop mode with RTC. When I active the stop mode, the current consumption is around 1mA, which still is far away from the consumption mentioned in the datasheet. (In the stop mode, I already configure all GPIO to Analog no pull mode). How to fix this? Please recommend for me some solution. Thank you.
my MCU is STM32WLE5CBU6
ngodoanvan
ngodoanvanBest answer
Jun 13, 2022 8:36 AM UTC
about 1 day I search this problem at ST Community. I found the TCXO is always enabled in my configuration and DEBUGGER_ENABLED is 1 therefore the current consumption is around 1mA. I fixed.0693W00000NrhyHQAR.pngThanks for your support.
Louis AUDOLY
Jun 13, 2022 8:15 AM UTC
Hello @Ngô Vạn​,
How are you measuring your current consumption ?
Otherwise you can check the SubGHZ_Phy_PingPong example from STM32Cube_FW_WL_V1.2.0 which have STOP mode working to compare the two projects, and/or under Projects\NUCLEO-WL55JC\Examples\PWR\PWR_STOP2_RTC you can find what you are looking for.
Let me know
ngodoanvan
ngodoanvanAuthorBest answer
