How to change the Data rate for sending more than 11 bytes using I-CUBE-LRWAN? #LoRaWAN #I-CUBE-LRWAN #B-L072Z-LRWAN1
We are using B-L072Z-LRWAN1 for developing our application. We are struggling to send more than 11 bytes of application payload. As long as the total payload is 11 bytes, the node joins the network with no issues. When we try to change the DR > 0 so we can push payload more than 11 bytes, then we need null data on fort 0 and the DR is reset back to DR 0 on the node after a join acceptance.
How do we properly change the DR to send data of more than 11 bytes? We are using US 915. Any insights from this forum members will be appreciated.
Sincerely,
Sid
