Luciano.Neri
Jan 15, 2021 2:27 PM UTC
How to add more than five characteristics each service?
I have to design a wb55 firmware which expose one service with twelve characteristics, but using CubeMX there are no ways to add more than five characteristics for each service.
There is a tip to skip this limit (also modifying the CubeMx automatic source code) ?
Thanks in advance
Luciano.Neri
Jan 18, 2021 8:23 AM UTC
Solved adding manually the characteristic and services, skipping the template create by CubeMx, and adapting the [service_max_attribute_record] parameter on aci_gatt_add_service.
