How to add I2C to I-CUBE-LRWAN SDK SubGHz_Phy example? The reason I'm looking for it is that I was able to run SubGHz_Phy successfully but I'm unable to add the I2C to run successfully.
It's very hard to add it without instructions to not break existing infrastructure with LoRa.
When I run simple example generated from classic .IOC file I got the I2C running without a problem.
The board I'm using: Murata Type 1SJ
