Member
May 9, 2021 4:56 AM UTC
How do I check registers on the Development Board Nucleo WB55?
I would like to look at the register to see which values are stored inside that register. Then I would like to use that number to do operations.
May 9, 2021 2:43 PM UTC
All the registers are accessible by the processor, read them, print them out, whatever.
Check them with the debugger
May 10, 2021 5:40 PM UTC
This is a very generic question. Registers are defined in the header files. You access them just like you would access a variable. For example, you can read a timer's counter register by accessing TIM1->CNT.
Member
MemberAuthor
May 10, 2021 5:42 PM UTC
To clarify, I wanted to check the registers for the RTC. How do I find the values of the time and date in the registers?
May 10, 2021 5:53 PM UTC
RTC time/date is in RTC->TR and RTC->DR. Look up the format in the reference manual.
