EKame.1
Dec 29, 2021 5:19 PM UTC
Hi, I am using STM32WLE5CCU6 MCU and I am trying to enable RTC Wakeup Interrupt. I use HAL_NVIC_EnableIRQ(RTC_WKUP_IRQn) but seems like my code is stuck inside it. Any ideas what can be causing that?
Dec 29, 2021 8:41 PM UTC
Sounds like it’s stuck in an IRQ handler. Make sure flags are cleared appropriately. Debug your code. Hit pause. See where it’s at.
EKame.1
EKame.1Author
Dec 29, 2021 11:17 PM UTC
how is it stuck inside IRQ handler? I have printed some logs and It doesn't get out from this HAL_NVIC_EnableIRQ(RTC_WKUP_IRQn)
Dec 30, 2021 12:13 AM UTC
You enable an interrupt. Code doesn’t progress from that point. What other explanation would there be?
Debugging is likely to be more fruitful than guessing.
Dana Myers
Senior
Dec 29, 2021 9:52 PM UTC
Do you have an ST/Link ? Relatively inexpensive. Highly recommended.
Dana K6JQ
EKame.1
EKame.1Author
Dec 29, 2021 11:18 PM UTC
yes I have it
Dana Myers
Senior
Dec 29, 2021 11:28 PM UTC
Have you tried running under the debugger, then halting to see what the MCU is doing when it's stuck?
Subramanya A
Apr 4, 2023 3:22 PM UTC
Hi @EKame.1​ ,
Any update for aforementioned issue ? even I faced same issue [https://community.st.com/s/question/0D53W00002DAe0dSAD/stm32wl-rtc-hangs]
Thanks in Advance.
