JayDev
Senior
Sep 21, 2020 8:55 PM UTC
Help with LP Sleep mode (getting Sysclk under 2Mhz)
Hello!
I'm working with an STM32-WB55 nucleo board and trying to put the board into sleep mode. In trying to plan the clocks, I've been working with the *.ioc file to figure out a way to make it work so I know what clock settings to use to put in in low power sleep mode (which requires a sysclk of under 2 MHz).
I have two basic problems:
1) If I get my sysclk down below 2 MHz, I get a warning with HCLK1 (which has to be over 14 Mhz, according to the framework)
2) I'm not sure if my proposed solution to get down to 2 MHz is the best approach (it looks like it will work but wasn't sure if this is the best approach)
I'm going to attach my current setup:
Here is the generated code:
void SystemClock_Config(void)
 RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
 /** Macro to configure the PLL multiplication factor
 __HAL_RCC_PLL_PLLM_CONFIG(RCC_PLLM_DIV2);
 /** Macro to configure the PLL clock source
 __HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSE);
 __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;
 RCC_OscInitStruct.HSEState = RCC_HSE_ON;
 RCC_OscInitStruct.HSIState = RCC_HSI_ON;
 RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
 RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
 Error_Handler();
 /** Configure the SYSCLKSource, HCLK, PCLK1 and PCLK2 clocks dividers
 RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK4|RCC_CLOCKTYPE_HCLK2
 |RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
 RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
 RCC_ClkInitStruct.AHBCLK2Divider = RCC_SYSCLK_DIV1;
 RCC_ClkInitStruct.AHBCLK4Divider = RCC_SYSCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
 Error_Handler();
 /** Initializes the peripherals clocks
 PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SMPS|RCC_PERIPHCLK_USART1
 |RCC_PERIPHCLK_LPUART1|RCC_PERIPHCLK_I2C1
 |RCC_PERIPHCLK_I2C3|RCC_PERIPHCLK_USB
 |RCC_PERIPHCLK_ADC;
 PeriphClkInitStruct.PLLSAI1.PLLN = 12;
 PeriphClkInitStruct.PLLSAI1.PLLP = RCC_PLLP_DIV2;
 PeriphClkInitStruct.PLLSAI1.PLLQ = RCC_PLLQ_DIV4;
 PeriphClkInitStruct.PLLSAI1.PLLR = RCC_PLLR_DIV8;
 PeriphClkInitStruct.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_USBCLK|RCC_PLLSAI1_ADCCLK;
 PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
 PeriphClkInitStruct.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
 PeriphClkInitStruct.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
 PeriphClkInitStruct.I2c3ClockSelection = RCC_I2C3CLKSOURCE_PCLK1;
 PeriphClkInitStruct.UsbClockSelection = RCC_USBCLKSOURCE_PLLSAI1;
 PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI1;
 PeriphClkInitStruct.SmpsClockSelection = RCC_SMPSCLKSOURCE_HSI;
 PeriphClkInitStruct.SmpsDivSelection = RCC_SMPSCLKDIV_RANGE0;
 if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN Smps */
 /* USER CODE END Smps */
Below is what I was looking at using (which clearly has an issue with HCLK1 being too low):
Below is the code that is generated:
 |RCC_OSCILLATORTYPE_MSI;
 RCC_OscInitStruct.MSIState = RCC_MSI_ON;
 RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
 RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
 Error_Handler();
 RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
 Error_Handler();
 |RCC_PERIPHCLK_ADC;
 Error_Handler();
I'm not 100% sure what to do to resolve the warning or what the effects of these changes would have on the performance of the device (maybe this is an expected hurdle when you run in LP mode?).
Anyway, let me know if you guys have any suggestions (either for clock changes or how to resolve the above HCLK1 error).
Thanks!
