Dec 4, 2023 1:39 PM UTC
Hardware/fuse disabling OTA updates for security?
Hi All!
We have a requirement to disable OTA updates either via hardware or by settings a fuse, this is due to the need for a low-maintaince, low-complexity, high-security method to prevent updates to those without physical access to the device.
Is there a fuse or fuses that can be used for this purpose? Or maybe a PIN that can be used for this?
We're looking to disable the OTA (aka FUOTA) for the STM32WLE5CBU6 which is listed as OTA capable in the datasheet.
Thanks all! :D
STTwo-32
STTwo-32Best answer
Jun 20, 2024 10:18 AM UTC
Hello @billyjoel
There is no way to do that. FUOTA is purely software and does not check hardware settings.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @billyjoel
Best Regards.
STTwo-32
