DS.4
Senior
Jan 25, 2024 9:41 AM UTC
__HAL_RCC_LSEDRIVE_CONFIG() WB55 vs WB5MMG
I see a higher drive in the WB55MMG
#ifdef WB55
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
#else WB5MMG
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_MEDIUMHIGH);
#endif // MIGO_BORAD
would like to preserve as much power as possible, what are the consequences of using it _LOW?
STTwo-32
STTwo-32Best answer
Jan 26, 2024 8:59 AM UTC
Hello @DS.4
It is recommended to use the LSE Medium-high drive to get a reliable LSE oscillation. It may work perfectly with the LOW drive, but we can't guarantee that.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @DS.4
Best Regards.
STTwo-32
DS.4
DS.4Author
Senior
Jan 30, 2024 3:49 PM UTC
Can you tell the effect it has on power consumption?
STTwo-32
Jan 30, 2024 5:53 PM UTC
Sure, the low drive is the best choice for power consumption.
Best Regards.
STTwo-32
