Mattia Poletti
Jun 14, 2018 4:54 PM UTC
HAL_InitTick substituted for LoRa
Posted on June 14, 2018 at 18:54
i see that in the CUBE for lorawan, the HAL_InitTick function has been rewritten, with a simple return and does nothing, replacing the standard in the HAL_drivers, so the timeout function of every other HAL don't work due the HAL_GetTick function that don't work.
What can i do to reintroduce the possibility of reading Ticks without break everything, and why this has been deactivated?
Thanks in Advance
#lora
Jun 14, 2018 5:05 PM UTC
Posted on June 14, 2018 at 19:05
Because they are turned off SysTick, not all CM0 have SysTick as I recall, and running it constantly has been deprecated over using the RTC to provide the periodic time base.
Seem to recall making HAL_GetTick() advance based on repetitive calls and available time bases.
Mattia Poletti
Jun 14, 2018 7:20 PM UTC
Posted on June 14, 2018 at 19:20
Thanks for the reply, now it's clear.
What do you mean? I have to rewrite the HAL_GetTick() or add a SysTick_Handler ?
