barmy
Jan 22, 2020 12:35 PM UTC
getting error - program "gcc" not found in the path
0690X00000BwKYmQAN.pngI am trying to execute ping pong experiment with B-L072Z-LRWAN1 discovery kit using STM32CubeIDE. I have used the codes which are available on stm32 website along with firmware . After bringing the project file in IDE problem window is showing error-
program "gcc" not found in the path.
also on building , consoles shows no error but the previous problem persist.
On debugging the process terminates with message - binaries not found
also there is no binaries file created in project explore window.
I have tried this code with other IDE (like True studio, eclipse ) but getting same error.
please suggest why this is happening and how to rectify that.
Jan 22, 2020 1:19 PM UTC
Your PATH environment variable doesn't adequately describe where your compiler is installed. Perhaps also consider that it needs to be the ARM EABI compiler not the native x86 tools.
A simpler route might be to use the Keil tools with the ST CM0 license.
dbgarasiya
Senior
Jan 25, 2020 8:19 AM UTC
Window -> Preferences -> C/C++ -> Build-> Environment
set as defaults may solved out problem in such case
