FP-ATR-LORA1 software using Only B-L072Z-LRWAN1 and GNSSA1A1 WITHOUT sensor Board does not compile properly. If I disable #define sensors as mentionned the compilation goes on tilt
No idea on how to resolve this problem. If I compile and run without the board the message is error on init the sensor board. Any clues?
