DS.4
Senior
Feb 5, 2024 11:39 AM UTC
Fixed_Pin change between connections
Curious regarding using ACI_GAP_SET_AUTHENTICATION_REQUIREMENT to change the fixed pin after already using a different pin key for a previous connection.
Would that work?
Any bad consequences?
Joe_Best answer
Feb 8, 2024 10:23 AM UTC
Hi DS.4,
It's important to make sure that you are not in a connected state when changing the fixed pin.
This should work and not cause any problems.
Don't hesitate to let us know if it worked ;).
BR, Joé
Joe_Best answer
Hi DS.4,
BR, Joé
DS.4
DS.4Author
Senior
Feb 8, 2024 11:17 AM UTC
 Changing it after I complete bonding , and it looks fantastic.
So next connection does get to use the new key. So far so good!
thanks
