Aug 22, 2024 6:42 AM UTC
Expected value for Option Byte "RDP": 0xBB, found: 0xAA
I am working on LoRa-E5 mini. When I try to erase the chip, I receive the error Error: Mass erase operation failed. Please verify flash protection. So I am trying to set RDP on level 0 to 1, but I am getting an Error: Expected value for Option Byte "RDP": 0xBB, found: 0xAA Error: Option Byte Programming failed or modified by application after OB_LAUNCH.
Any help would be greatly appreciated.
STTwo-32
Aug 22, 2024 7:03 AM UTC
Hello @Niki_Nagar
I've tested this on an STM32WL Nucleo board but I'm not able to reproduce your issue. I think that your post on the forum of our third-party should be helpful since it could be something related to the third-party implementation. Also, this post and others should be helpful
Best Regards.
STTwo-32
Aug 22, 2024 7:17 AM UTC
Thank you @STTwo-32
Can you tell me, what are the reasons why does it occur?
STTwo-32
Sep 20, 2024 6:09 PM UTC
It may be due to something on our third party's implementation. It will be better to check directly with them.
Best Regards.
STTwo-32
