Romaszewski
May 29, 2024 4:08 PM UTC
error in generate code for stm32WBA54 with MX tools
For your information
Sizeof is used in place of strlen and my coordinator receive a \0x00 at the end of the string !!
when i generate code with MX generation tools, in function : in red old code in green new code
void APP_ZIGBEE_ConfigBasicServer(void)
static struct ZbZclBasicServerDefaults stBasicServerDefaults;
/* Initialize Basic Server Cluster 'defaults' information */
memset( &stBasicServerDefaults, 0x00, sizeof(stBasicServerDefaults) );
stBasicServerDefaults.mfr_name[0] = sizeof strlen( APP_ZIGBEE_MFR_NAME );
memcpy( &stBasicServerDefaults.mfr_name[1], APP_ZIGBEE_MFR_NAME, sizeof( APP_ZIGBEE_MFR_NAME ) );
stBasicServerDefaults.model_name[0] = sizeof strlen( APP_ZIGBEE_CHIP_NAME );
memcpy( &stBasicServerDefaults.model_name[1], APP_ZIGBEE_CHIP_NAME, sizeof( APP_ZIGBEE_CHIP_NAME ) );
stBasicServerDefaults.date_code[0] = sizeof strlen( APP_ZIGBEE_APP_DATE_CODE );
memcpy( &stBasicServerDefaults.date_code[1], APP_ZIGBEE_APP_DATE_CODE, sizeof( APP_ZIGBEE_APP_DATE_CODE ) );
stBasicServerDefaults.sw_build_id[0] = sizeof strlen( APP_ZIGBEE_APP_BUILD_ID );
memcpy( &stBasicServerDefaults.sw_build_id[1], APP_ZIGBEE_APP_BUILD_ID, sizeof( APP_ZIGBEE_APP_BUILD_ID ) );
STTwo-32
May 29, 2024 4:57 PM UTC
Hello @Romaszewski
Can you share your .ioc file so we can reproduce this behavior.
Best Regards.
STTwo-32
Romaszewski
May 29, 2024 5:09 PM UTC
STTwo-32
May 29, 2024 6:02 PM UTC
I'm not able to reproduce that issue. Could you give more details and the steps to reproduce this issue.
Merci Beaucoup d'avance.
STTwo-32
Romaszewski
Jun 6, 2024 9:24 AM UTC
Do you have a procedure to inform the team of development of MX tools for this error ?
STTwo-32
Jun 12, 2024 2:56 PM UTC
Hello @Romaszewski
I've raised this internally for more investigation (under internal ticket number 184049).
Best Regards.
STTwo-32
