Oct 10, 2024 7:18 AM UTC
Dynamic Range of STM32WLE5 RF reciever
Hi ,
I see in the Datasheet in Table 31 some reciever parameters .
I need to know what is the Dynamic Range of the Reciever in the STM32WLE5 . can you point me to which parameters should I look at ?
Thank you
Viola
STTwo-32
STTwo-32Best answer
Oct 10, 2024 4:50 PM UTC
Hello @viola
This depends on the RX sensitivity since it is the minimum signal level that the receiver can detect. But also, it depends on the position of the reception node, the used antenna, the electromagnetic interference that may happen due to the co-existence of different signals and finally the RF design.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @viola
Best Regards.
STTwo-32
