Senior III
Jan 12, 2026 1:45 PM UTC
DWT timing question
P-NUCLEO-WB55
Just a sanity check really.
I'm using the DWT unit to time a chunk of code, am I right that each tick is at 1/32MHz?
TDKBest answer
Jan 12, 2026 1:52 PM UTC
The DWY CYCCNT tick rate will be the same as the core clock. By default, it is 32 MHz.
TDKBest answer
