Mar 26, 2025 11:18 PM UTC
Duplicated uwTimclock initialization code - STM32WBA - CubeMX 6.14.0
When "Middleware and Software Packs" > STM32_WPAN is enabled in  CubeMX, a duplicated initialization's code for uwTimclock is generated:
That code is outside the if-else block overriding the previous configurations which could produce issues.
  • Any idea about what could be wrong?
Note: I attached the .ioc file.
Details:
  • CubeMX version: 6.14.0
  • File: stm32wbaxx_hal_timebase_tim.c
STTwo-32
STTwo-32Best answer
Mar 27, 2025 9:05 AM UTC
Hello @mpc and welcome to the ST Community.
I've been able to reproduce this behavior, and I've reported internally for correction on the Future (under internal ticket number 206323). Thank you so much for your contribution.
PS: this has been solved on the version 6.15.0 of the STM32CubeMX.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
mpcAuthor
Mar 27, 2025 10:56 PM UTC
I will be pending of new releases versions. Thank you .
