PLilj.1
Explorer
Oct 29, 2021 3:52 PM UTC
Does STM32WB55 have embedded pull-up resistor on USB_DP?
In AN4879 FAQ it is stated to check "Table 3. USB implementation in STM32 devices" whether the USB_DP line has an embedded pull-up resistor.
STM32WB55 is not in that list. Can you confirm if the STM32WB55 has embedded pull-up resistor on USB_DP or not?
Oct 29, 2021 4:09 PM UTC
Per the reference manual, it has an embedded resistor on USB_DP.
USB connect / disconnect capability (controllable embedded pull-up resistor on USB_DP line)
垒垒.1
Nov 6, 2021 3:44 AM UTC
YES!the STM32WB55 has embedded pull-up resistor on USB_DP.
