May 11, 2026 8:37 AM UTC
Difference between MB1720 High_band Low_power and MB1720 High_band High_power input differential when applying to the same RF mesh network
I noticed that the MB1720 High_band Low_power configuration and the MB1720 High_band High_power configuration have different input line differentials. I would like to know, when combining High_band/Low_power nodes with High_band/High_power nodes in the same RF mesh network, what design considerations should be followed and how the part should be designed?
Thank you.
Saverio GRUTTA
May 13, 2026 6:10 AM UTC
To confirm my understanding: are you asking how to design a single matching network that supports both 864 to 928 MHz at 15 dBm and 864 to 928 MHz at 22 dBm configurations, given that we recommend different reference designs  for each configuration?
Best regards
Saverio
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
