Nov 13, 2025 3:55 PM UTC
Custom Wio-E5-LE PCB draws 88 µA in sleep — datasheet says 2.1 µA
Hi everyone,
         I’m facing an issue with power consumption on my custom PCB that uses the Wio-E5-LE module. According to the datasheet, the module should consume around 2.1 µA in sleep mode, but my board is drawing around 88 µA instead. I’ve double-checked everything and can’t find any other source of leakage.
What i have already checked,
  • Disabled all unused peripherals
  • Configured all GPIOs properly
  • Verified there are no shorts or solder bridges on the PCB
  • Measured current draw of other components — none show any noticeable leakage
Andrew Neil
Nov 13, 2025 4:11 PM UTC
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
In particular, please show your schematic.
Some good, clear photos may also help.
@Saarankan wrote:
According to the datasheet...
Which datasheet is that - the module's datasheet, or chip datasheet?
Have you contacted Seeed Studio? The module is their product:
https://aftersale.seeedstudio.com/home
https://discord.com/invite/QqMgVwHT3X
https://forum.seeedstudio.com/
JBive.1
Nov 17, 2025 8:46 AM UTC
I am not familiar with the Wio-E5-LE module. However, the µA-figures you mentioned match the numbers in this post:
https://community.st.com/t5/stm32-mcus-wireless/b-wl5m-subg1-stm32wl5moc-current-consumption-too-high/m-p/856159
Maybe this post can give you a hint?
BR
Jonas
