Senior
Apr 19, 2024 3:35 PM UTC
Creating a LoraWAN server on an stm32 chip
I am making a device that is to take pulse outputs which have been converted to wireless LoRaWAN signals, and convert it back again into a hardwire pulse output. For the receiving device, I intend to use a modem board PN 109990166 connected to an STM32L476RG. Is it possible to make a simple LoRaWAN server on the stm32F4 whose primary purpose is to take the wireless data and convert it to pulse output? If not, what other wireless protocols would be good for this application? The transmitter doesn't have to be LoRaWAN.
Tesla DeLoreanBest answer
Apr 19, 2024 3:47 PM UTC
LoRaWAN or LoRaP2P ?
Definitely had LRWAN library running on L4 and F4 parts.
Not really a Gateway, as that uses a SX130x part, which has multiple receive channels, to capture different nodes/bands. Software wasn't open.  https://www.st.com/en/evaluation-tools/p-nucleo-lrwan3.html
To create a board that can receiver LoRa radio signals, and generate pulse output, or servo PWM, something simple/singular like this would suffice.
https://www.st.com/en/evaluation-tools/b-l072z-lrwan1.html
The Ping-Pong example shows point-to-point communication, and that can be cut down to make one a transmitter, and one a receiver, without any gateway or server
Senior
Apr 19, 2024 3:41 PM UTC
Sorry, I meant to say stm32L4, not stm32F4
Apr 19, 2024 3:48 PM UTC
There's a 'V' icon to the upper right of the post, gives you a drop-down menu with an Edit option.
Senior
Apr 19, 2024 5:04 PM UTC
Thanks, I was looking for that.
Senior
Nice, man! I am unfamiliar with the different kinds of LoRa options, and it looks like the LoRaP2P & this dev kit seems to be exactly what I need. Thank you!
