Can You Explain the Current Mode and Status of My Microcontroller?
- 6 replies
- 823 views
I am currently developing a board using the STM32WB09TEF7TR microcontroller.
Unfortunately, when the device is powered on, the microcontroller does not function properly.
It only starts working after manually resetting the reset pin.
To diagnose this issue, I am accessing the memory immediately after powering on the device in hot-plug mode to check its status.
The register bit log data is attached.
Could you help me understand the current state of this microcontroller?
