Sep 7, 2025 5:05 PM UTC
Cable replacement feature on Android
We need some help with cable replacement feature. Our project using WB1M as a client device, sharing data over UART. Android application must be server. STBLESensor_Android source code not include any sample code with Cable replacement feature. Were we can get one?
STTwo-32
STTwo-32Best answer
Sep 7, 2025 8:37 PM UTC
Hello @pm_interrupt_vect
Such panel is not one of the implemented panels. So, you may need to do it on your own by following the same implementation on the ST application.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
