Senior
Sep 20, 2024 6:50 AM UTC
Board support package
I have a very generic question ,What happens if in an example for a different board . I just remove the BSP and instead add a BSP for a different board.
Pavel A.
Pavel A.Best answer
Sep 20, 2024 9:08 AM UTC
A generic answer to the generic question. When you replace or adapt a BSP from a different board you
1.Make it build without errors, find all missing parts etc.
2. Debug and validate that it works.
What happens next depends on success of these two steps.
Pavel A.
Pavel A.Best answer
Andrew Neil
Sep 20, 2024 12:40 PM UTC
To be even more generic:
"When you replace or adapt any firmware from a different board you ..."
RiturajAuthor
Senior
Sep 21, 2024 3:54 AM UTC
@Andrew Neil Your sarcasm wasn't required here.
