Apr 27, 2024 5:31 PM UTC
BLE Stack modify the RCC configuration
HI,
     I am developing my ble audio project with STM32WBA55G-DK1. I need use SAI interface as audio input interface. I have an annoying problem. I configure RCC before init ble stack. I choose use pll1rclk as system clock. But i call the BleStack_Init function to init ble stack which provide by ST, the register of  RCC_CFGR1 changed from 0xF to 0x0, HSI16 becomes as system clock. I can't understank why the Ble stack do that。 If so that, does it mean that the maximum system clock can only be 16M when using Bluetooth function?
STTwo-32
STTwo-32Best answer
May 30, 2024 2:29 PM UTC
Hello @Xiaojie
Could you send a .ioc file that may help us to reproduce this issue. I've tried to reproduce it on my side but is not possible.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Xiaojie
Best Regards.
STTwo-32
XiaojieAuthor
May 31, 2024 1:45 AM UTC
HI,
   I known where change the RCC configuration.  LINKLAYER_PLAT_RCOStartClbr and LINKLAYER_PLAT_RCOStopClbr call  scm_setsystemclock,which willchange the RCC configuration.
It is related to RCO calibration。What is RCO?
