AWack
Aug 29, 2024 6:54 AM UTC
BLE Sensor network with only STM32WB (NO iPhone or Android!)
I want to send sensor data from several sensors with STM32WB to another STM32WB (the main controller in my system). Unfortunately I only find examples where communication is established between STM32WB and a smartphone or similar, but not with a STM32WB as the "central".
Is there any example / hints?
Best regards,
Achim
STTwo-32
STTwo-32Best answer
Aug 29, 2024 10:07 AM UTC
Hello @AWack
What I suggest you is to follow the BLE_p2pRouteur for the STM32WB55 and BLE_p2pRouter for the STM32WB0. Then, you can modify it or inspire from it to keep just the central part and configure the peripheral part of the Router if you need to share the data as a router or you can share this data too from a serial monitor or whatever you do.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @AWack
Best Regards.
STTwo-32
