Ofer
Sep 8, 2019 2:05 AM UTC
BLE Scanning on single channel only ability. Can the STM32WB scan only one of the 3 channels (ch37/ch38/ch39) ?
Remi QUINTIN
Sep 9, 2019 11:35 AM UTC
​It should be possible using the HCI_LE_SET_ADVERTISING_PARAMETERS command that enables the selection of the  advertising channel map ( Advertising_Channel_Map parameter). Note that this call must be done before the GAP command that triggers the scanning.
Ofer
OferAuthor
Oct 20, 2019 12:28 AM UTC
Thanks Remi
I asked about one channel scanning ability - not about one channel advertising ability.
Remi QUINTIN
Oct 22, 2019 3:13 PM UTC
​ We are not aware of any BLE command enabling the possibility to scan only 1 single channel.
At least this is not supported with our BLE stack.
