Senior
Aug 2, 2024 3:30 PM UTC
BLE MESH ADDING Services
I have two stm32wb5mm dk configured as mesh server and client . I used example  BLE_MESH_MODEL_SENSOR. Can someone tell me what file mentions the data that is being sent and how can I add external sensor or a way to add external service so that it can be utilised. Also how can I limit the number of nodes required because i need to use just these two and a smartphone which should recieve the data.
STTwo-32
Aug 9, 2024 3:36 PM UTC
Hello @Rituraj
I suggest you debug the original BLE_MESH_MODEL_SENSOR to understand how it works. You can also take a look at the AN5292. Also, you can refer to this wiki. Some research on those Resorces should do the job for you.
Best Regards.
  STTwo-32
