A&A
March 8, 2021
BLE: How can I get a SCAN REQUEST event?
Recently I started working with Nucleo board with STM32WB55 and I would appreciate if somebody could help me with this issue about BLE. I never worked with the BLE stack before and I am quite lost and confused.
I am working in a project where I only need to detect the SCAN REQUEST. In the learning process of STM32WB, I found the very useful MOOCs and more specifically “STM32WB Workshop – 3 How to add BLE funcionality�?. It Works with the project “HandsOn2�? supplied by ST.
https://www.youtube.com/watch?v=zNfIGh30kSs&list=PLnMKNibPkDnGRfqUO1Q_-1nW-tOKfDQbc&index=4
Among other things, it explains how to blink a LED every time a radio RF activity finishes, using Radio Activity Event. I thought following the steps of this event would be a good way to get a SCAN REQUEST event, but unfortunately so far I have not achieved anything.
Please find below the pseudo code of app_ble.c file, where the radio RF activity is mentioned.
-         In the APP_BLE_Init() funtion the radio activity event mask is defined:
aci_hal_set_radio_activity_mask(0x0006);
-         In the SVCCTL_App_Notification() function you could find ACI_HAL_END_OF_RADIO_ACTIVITY_VSEVT_CODE, and here is where the previously mentioned LED blink is set.
void APP_BLE_Init( void )
#if(RADIO_ACTIVITY_EVENT != 0)
#endif
SVCCTL_UserEvtFlowStatus_t SVCCTL_App_Notification( void *pckt )
 hci_event_pckt *event_pckt;
 evt_blue_aci *blue_evt;
 event_pckt = (hci_event_pckt*) ((hci_uart_pckt *) pckt)->data;
 switch (event_pckt->evt)
 case EVT_DISCONN_COMPLETE:
 	break;
 case EVT_LE_META_EVENT:
 	break;
 case EVT_VENDOR:
 blue_evt = (evt_blue_aci*) event_pckt->data;
 switch (blue_evt->ecode)
 // SPECIFIC to P2P Server APP
 case EVT_BLUE_L2CAP_CONNECTION_UPDATE_RESP:
 		break;
 case EVT_BLUE_GAP_PROCEDURE_COMPLETE:
 break;
 case ACI_HAL_END_OF_RADIO_ACTIVITY_VSEVT_CODE:
 	/* USER CODE BEGIN RADIO_ACTIVITY_EVENT*/
		// Blink Green LED every time radio RF activity finishes.
 HAL_GPIO_WritePin(LED_GREEN_GPIO_Port, LED_GREEN_Pin, GPIO_PIN_SET);
 	HAL_Delay(5);
 	HAL_GPIO_WritePin(LED_GREEN_GPIO_Port, LED_GREEN_Pin, GPIO_PIN_RESET);
  	/* USER CODE END RADIO_ACTIVITY_EVENT*/
 break;
	 #endif
 }// switch (blue_evt->ecode)
 break; /* EVT_VENDOR */
 default:
 	break;
 }// switch (event_pckt->evt)
 return (SVCCTL_UserEvtFlowEnable);
So, how should I define scan request event mask?.
Should I use aci_hal_set_event_mask()?
In that case, should it be aci_hal_set_event_mask(5) or aci_hal_set_event_mask(1)?
Where should I locate case ACI_HAL_SCAN_REQ_REPORT_VSEVT_CODE: in switch (event_pckt->evt) or in switch (blue_evt->ecode).
The point is that I tried every combinations but it doesn´t work. I´m afraid I´m wrong and I´m missing something, but I don´t know what? Any help will be appreciated.
Thank you in advance.
