koteeq
Sep 24, 2022 9:13 PM UTC
BLE Additional beacon feature does not work
Calling "aci_gap_additional_beacon_start" first works successfully, but calling "aci_gap_set_discoverable" after that returns "0x0C Command disallowed".
If I swap these instructions and set up the main advertisement first, I get the same 0x0C error trying to set up an additional beacon.
Please find the code example here: https://github.com/flipperdevices/flipperzero-firmware/blob/zlo/additional_beacon_test/firmware/targets/f7/ble_glue/gap.c
Main advertisement initialization is contained in the "gap_advertise_start" function. Beacon initialization is inside "beacon_start".
Radiostack versions used: 1.13.3 Lite, 1.14.1 Lite
Remy ISSALYS
Remy ISSALYSBest answer
Oct 12, 2022 2:56 PM UTC
I checked your code and I think I found the root cause of your issue, to support advertising and additional beaconing feature, you should have at least to support 2 links. To do this, change the value of the following define in app_conf.h file:
#define CFG_BLE_NUM_LINK 2
Best Regards
koteeq
koteeqAuthor
Sep 25, 2022 12:50 PM UTC
Update: I also tried 1.14.1 Lite, but no luck.
Remy ISSALYS
Oct 7, 2022 3:55 PM UTC
Are you using P-NUCLEO-WB55 Nucleo board or a custom board? Did you try to start from an example of STM32CubeWB package for example BLE_p2pServer?
Best Regards
koteeq
koteeqAuthor
Oct 7, 2022 4:00 PM UTC
Hi @Remy ISSALYS​!
I am using a custom board, namely a Flipper Zero device. Unfortunately, I don't have a Nucleo board, and I'm not experienced enough to compile bare BLE_p2pServer for Flipper Zero.
However, all BLE advertising initialization code can be found here, including the attempt to use additional beacon: https://github.com/flipperdevices/flipperzero-firmware/blob/zlo/additional_beacon_test/firmware/targets/f7/ble_glue/gap.c
Remy ISSALYS
Best Regards
koteeq
koteeqAuthor
Oct 12, 2022 3:09 PM UTC
Thank you, Remy, this helped.
