Jan 31, 2025 8:45 AM UTC
B-WL5M-SUBG1 Demonstartion Software Source Code
Hi there!
I'm just starting with the B-WL5M-SUBG1 and would like the source code for the program that runs on a newly purchased development board. The documentation says this code is available https://www.st.com/resource/en/data_brief/b-wl5m-subg1.pdf section 2.3.
However, I've searched and cannot find it anywhere. Can someone help?
Here's the application output:
Many thanks!
David
MOBEJ
Jan 31, 2025 9:03 AM UTC
Hello @davidn ,
You can find the demo by downloading the latest package from the ST.com website (not from GitHub). Follow this path: STM32Cube_FW_WL_V1.3.0\Projects\B-WL5M-SUBG1\Demonstrations. You will find the  B-WL5M-SUBG1 demo there.
Regards ,
davidnAuthor
Jan 31, 2025 12:12 PM UTC
Hello @MOBEJ
I've looked through the code on the Demonstration sample you advised. It does'nt look like it produces the output (on the screenshot). The software running on my board looks like a comprehensive test system.
Could you check again?
Thank you
David
