S.M.
Apr 12, 2019 9:17 PM UTC
B-L072Z-LRWAN1 Current Consumption
I am using B-L072Z-LRWAN1 and AT_Slave project from I-Cube-LRWAN. Can Anyone help me with the setup to measure current consumption like jumper position and across which pins to measure current?
Thank You
Clive1 (HNL)
Explorer
Apr 12, 2019 10:59 PM UTC
The manual describes JP1, JP2 and JP3 and the related solder bridges SB19, SB14 and SB17, start with those perhaps?
https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/ac/62/15/c7/60/ac/4e/9c/DM00329995/files/DM00329995.pdf/jcr:content/translations/en.DM00329995.pdf
I think @Andrew Neil​ identified a couple of components in the battery path that could be removed also.
