Feb 18, 2025 11:48 AM UTC
APS Layer configuration : Ack requirement
I'm trying to make an OnOff Switch emitter using zigbee on the STM32WB55 Nucleo Board. I started my project from the Zigbee_OnOff_Client_Distrib applications exemple.
The receiver that I use is not made to send back APS ACK. Because of this I add problems with Toggle command on the OnOff ZCL Cluster because the emitter was sending frame retries.
I figured out that I could disable Ack requirement in the APS Frame Control using
zigbee_app_info.onOff_client_1->txOptions &= ~(ZB_APSDE_DATAREQ_TXOPTIONS_ACK);
after cluster allocation.
Now, my problem is with the Zdo. In the find and bind process, I send a Simple Descriptor Request:
// /** Simple_Desc_req */
// struct ZbZdoSimpleDescReqT {
// uint16_t dstNwkAddr; /**< Destination network address */
// uint16_t nwkAddrOfInterest; /**< NWKAddrOfInterest */
// uint8_t endpt; /**< Endpoint */
// Request simple descriptor
struct ZbZdoSimpleDescReqT req_simple_desc;
req_simple_desc.dstNwkAddr = zigbee_app_info.SW1_endpoint_bind.nwkAddr;
req_simple_desc.nwkAddrOfInterest = zigbee_app_info.SW1_endpoint_bind.nwkAddr;
req_simple_desc.endpt = zigbee_app_info.SW1_endpoint_bind.endpoint;
ZbZdoSimpleDescReq(zigbee_app_info.zb, &req_simple_desc, simple_desc_response_cb, NULL);
when I check in the packet with a sniffer, I see that the Ack requirement in the APS Frame Control is set, and the emitter send frame retries.
My questions are :
 - How can I disable Ack requirement in the APS Frame Control for zdo requests?
 - Is there a way to configure the APS Layer globally?
Thank you,
OuadiBest answer
Feb 19, 2025 4:15 PM UTC
Hello @Nath,
Thanks for contacting us.
Please find my answers to your questions:
  • APS Acknowledgement is mandatory for all unicast ZDO Commands according to Zigbee specification, this allow to overcome transient routing leading to failures in the network.
  • Consequently, APS Ack can only be disabled for the ZCL layer at the cluster level as you mentioned.
Please find the paragraph from Zigbee spec :
Kind regards,
Ouadi
OuadiBest answer
Hello @Nath,
Kind regards,
Ouadi
NathAuthor
Feb 20, 2025 8:00 AM UTC
Hello @Ouadi,
Thank you for your answers.
