RobK1
May 22, 2026 8:12 AM UTC
Advice on antenna tuning ?
I am currently working to redesign one of our products to include Bluetooth communication for remote control. For this, I am targetting the STM32WBA23.
Given that the PCB is mounted inside a solid, cast-aluminium housing, I will need to put the antenna on a seperate board and connect it with a cable to the main PCB.
My question now is: Where do I put the tuning components? Do I place these on the main PCB, close to the controller, or do I put them on the antenna board?
Or maybe it doesn't actually matter.
I would appreciate any comments and directions by those more RF savvy than me.
Laurent LOUAZON
Laurent LOUAZONBest answer
Aug 20, 2026 9:11 AM UTC
I would suggest you implement STM32WBA matching/filtering right after STM32WBA RF pin on main PCB.
Then implement a dedicated antenna matching filter at antenna feedpoint on antenna board.
See AN5948 for recommandations.
Laurent
Laurent LOUAZON
Laurent
